Wimpy
I know I have seen this information here before, but my search turned up nothing. If someone has this info handy I would really appreciate it. I'm looking for the part numbers for the transmission upgrade kit and the latest TPS. I have a 2006 Classic. Thanks, Mike
The Uppgrade kit Black engine: t1000008
Silver engine: t1000009.
(more than just the transmission):
shifter bolt replaced.
Male & flemale threads were cleaned and primed using LOCTITE primer.
Then LOCTITE RED was applied and the bolt torqued to 29 newton-meters.
2nd gear was replaced and the gear that engaged 2nd gear.
lower cam chain guides replaced
lower cam pulley replaced
cam chain adjusters replaced
clutch parts (retainer bolt, several other bolts......... I don't remember)
new clutch springs (higher tension)
fuel level sensor
tune recall
