Only got 82% throttle = Q'
Dennsell
Top Fuel
Kawasaki Japan (Perth WA) (GY - UK)
Bonnie T 100, unfortunately not Rocket lll Country
Guys I was checking Ecu and Pcv this arvo and I ran through the tests
I am showing only 82% at full throttle so where has the other 18% gone,
Is TuneECU reliable and true in this reading ?
Not much adjustment left on the cables but I dont see how I can recover it there..
TPS I havn't touched yet..... but better get some new cables.
Any ideas or advise please
Hmmm interesting
sorry i cant help mate im sure someone will chime in soon i wonder if a tps reset will alter that reading
Could you not just remove an air filter, twist the throttle and look? Assuming that you have triple filters that is.
Thanks TR
I serviced it last w/end and didn't notice any probs with the linkage during operation.
But I will recheck tomorrow to be sure.. I was really wodering is TuneECU was acurate.
I'm fairly sure tune ecu is pretty much on the money Dennis mine always reads 100 when fully open
Sent from my iPhone using Tapatalk
Your cable hasn't slipped out of the little groove inside the grip has it mate ? That would give about an inch play and probably stop it from opening 100 percent ? Mine came out once . Might be worth a look
Dont think so mitch, no play in throttle..
I was going to lift the tank to today but fitted the floor boards etc..
Maybe when I did the work on the service.. greased all connectors.. I was just thinking perhaps a cable is stopping its travel.
Anyway thanks mate Ill get under the Tank and have a good look.. your saying TuneECU is pretty good so must be something else.
Maybe the bike used to be Red
