No spark at plugs
Haylo
R3
Hi there fellow bikers
Looking for some help I've currently got a 2004 R3 standard/classic.
The problem is no spark at the plugs??
I have checked voltages at the battery, coil feed & coil pulse sides of things these are my findings:
Battery 13.44v direct current ignition on 12.42v
engine cranking 9.96v
Coil feed, ignition off 0 volts
Ignition on 12.7v
Cranking 9.23v
Coil pulse, ignition off 0 volts
Ignition on 0.14 - 0.08v
Cranking 0.11v
Battery voltage after test 12.82v
Any thoughts!!!
you are going to need more voltage if you expect the rocket to start.
put a charger on it. or jump it with a car battery.
just a standard classics started in 2006
Take your battery to an Autozone or O'Reilley's to get load tested. It looks from your readings the voltage drop is severe. Also check your engine managaement relay. You can determine if the EMR is working if you have TuneECU and run the purge valve test. That test requires the relay to be closed for the purge valve to work, that has the same power source as the ignition coils (EMR).
