No indicators
Aussie
Standard Bore
07 rocket 3 .
hi all . Have an 07 rocket with 42000 kms on it. It has been a very good bike with no problems but I have just lost all my indicators. I checked the fuse it is fine. Tell tale light works on ignition but nothing a switch. Anyone had the same problems. If I have done this post wrong I'm open to pointers, first post. Thanks.
w
Has standard tyres. Wires look all good.
Welcome from Germany! Hopefully the relay solves your problem.
When you get a chance throw an introduce yourself thread up and let us know who you are, where you're from, etc!
Well sorted indicators . Bought a new flasher unit which solved the problem but they flashed way to fast. In the long turn triumph have there own hella unit off which you need to purchase of them. But I was a bit lucky I found a bit of solder fixed mine , the little steel flasher plate had come loose so saved a $100 plus. Thanks for all your help. For a bit of intro . Names Steve , live in the hunter valley NSW. Have a grafiite 07 classic. 42000 on it . Has been a good bike. Just getting ready for a trip to nth QLD.
