Off to SoCal on Friday (if possible) and my 2012 R3R has just developed a confusing problema.
When rolling the bike forward or back, or rotating rear wheel while off the ground, I have a rather serious clunk emanating from the axle or final drive area.
Thinking wheel bearings (which I replaced for PM last year) or God forbid, final drive, I began to remove the rear wheel today. Surprisingly, I discovered that after the rear axle nut was loosened the clunk totally disappeared! Tightened it back up and the clunk returned. WTF?
Whent ahead and removed rear wheel and after close inspection of the final drive, found nothing amiss. Looks as fresh and clean (excluding grease of course) with no fragments or signs of wear. Also checked bearings and they rotate smoothly with no side play.
ANY SUGGESTIONS OR IDEAS????
