T Evans
I have a set of Jardines that I am going to repack because they have gotten louder and louder. Turbofan posted a good article on this subject.
My question is, once you install the new packing, is this going to change your back pressure enough that it would require a retune to compensate from this?
I noticed in his article that they wrapped SS wire around the fiberglass on the new baffle which held the fiberglass on the baffle. If you greatly increased the amount of wire used by decreasing the distance of the wraps, I would think that would allow for more support of the fiberglass thus decreasing the amount of air that would be able to get thru the fiberglass. And to me this would also extend the life of the new fiberglass and instead of needing to repack them every 12k to 15k miles, you might be able to strech this out to maybe 20k
But by reducing the air flow out of the muffler, you increase the back pressure and the question is. Will it reduce the air flow enogh to require a change in the A/F mixture?
Anybody with expirence or thoughts on this?
Big T
Big T
