RockyIII
Brazil
Can anyone tell me where I manually adjust the idle after removing the stepper motor. Is there a screw somewhere, as I can't see anything to adjust idle.
After I removed the stepper motor there was no high revving on start up and it went straight to about 950rpm and then dropped a little to the 700's and after some minutes, slowly went upo to about 830-850rpm. Is this normal, does the ECU need to learn a bit, do I need to adjust the idle manually somehow?
Any info about all this would be great. Maybe I need to do nothing.
