Tatonka
.040 Over
Had the low fuel warning light fixed under warranty. It was going on at about 1/2 tank. Seems on occassion when the float is installed in the tank, the arm gets bent which affects the float rise and voltage pull.
Dealer straightened the arm and recalibrated, 2.4 volts dc should turn on the light with about 1 gallon left, it's not exact so the trip meter is a necessary back-up
