Latest Changes
I needed to go back to the triumph mounts so I could put the dress rails on but I modified them so I only undo the two main bolts from inside each of the bags it make it Quick change
Took your advice on this and did the same....saved me $160 from buying the ghost brackets. Thanks.
HansO,
Nice thoughtful work for the wife. It's good to have your partner ride with you once in awhile. :) Mine has only about three times in the past 38 years. It's just not her bag. :(
The Corbin does indeed look very nice. I have met and visited with Mike Corbin. He is stand up all the way and supports his products.
Was your "Gray Beard" Speaker headlight set up with those HD rims all plug and play or was there some grinding and alterting?
Nice work, Amigo!
1olbull
just need a steady hand to cut 13mm of the inside edge of the HD extended rims with a Dremel otherwise just plug and play, no grind or altering the original buckets
It is looking good mate, I also may go with those lights the originals on mine are not as good as I thought they may have been and we have a lot of wildlife to avoid where I live.
