BDClone
.040 Over
I had adjusted my throttle bodies and figured I would also do the ISCV adjustment in TuneECU. The Primary TPS is set to .60 volts the ISCV reads .63 volts. Adjusting the nut doesn't change anything. I have been trying to figure this out. I have the manual and have been going through all the posts to try to figure this out. I even watched R III R Turbo's vid on doing this adjustment.
I went out today and started trying to go through it again. Now my idle is up over 2700 rpm. What if I set my primary TPS to .12 under my ISCV reading? Any other ideas?
