I think my bike just had a stroke
ArekDeBoss
Turbocharged
Lalaland
Rocket 3 GT 2022
Went to work on the bike after few weeks of keeping it in a garage and replacing indicators.
On the way there all was fine. On the way back however first the service light came on ( had a service about 150 miles ago), then abs disabled, then started choking- loosing power for a fraction of the second and engine light coming up for couple of seconds, the TSC disabled . Got home 30 miles ISH and just in front of garage door engine stopped. After few attempts managed to start it back again.
Any ideas?
Maybe worth mentioning I filled up the tank just before heading back home
Any ideas?
after all these issues, you should buy tuneecu so at least you can diagnose the codes at home before going to dealer.
I would disconnect battery for 30min and see if that helps ECU else you have to read the engine light codes with tuneecu and post them here.
Any particular tune ecu tool?
Starting to venture in a field of complete black magic . Need to be guided by hand ;-)
I always advise my customers to read the codes and write them down .
The first thing i ask is what are the codes and has anybody been working on it.
A tank full of diesel will mess up the way it works.
You may have a half dozen codes but only one may be the culprit.
Auto zone will read the codes for free you just have to know that the 16 terminal connector is under the seat.
Hth
OBDLink LX OBD2 Bluetooth Scanner​
You also either need an Android phone or tablet to run TuneECU.
Adapters, to be able to remap (W) the latest Triumph models via Bluetooth
OBDLink LX
OBDLink MX
OBDLink MX+
For info on TuneECU start here... TuneECU_Start Here
Or bad gas.
I don't quite understand the reasoning behind this suggestion.
Why would bad gas trigger all the fault codes?
I can image perhaps some reaction from various sensors around the engine detecting bad burn in the combustion chamber, but before the dash starts shouting at you, surely the engine will be showing signs that combustion is deteriorating.
