I hear "rumbling" with clutch released
Willtill
Nitrous
Hanover, Maryland
My Rocket now has about 1300 miles on her; I hear "rumbling" in the front part of the crankcase with clutch released. Goes away when I squeeze the clutch lever. Is this normal? I asked the dealer about it and he said that is just the clutch basket.
Kindest regards,
-Will
Either the thrust washer is out of shape or one or more of the clutch plates have burs on them and are fighting with the anti rumble spring and pressure plate, I had this on a Kawasaki once and it was down to a crap quality thrust washer from manufacture, didn't cause any problems other than the noise, if it was a car it would be an indication of imminent thrust bearing failure but I have never seen a real thrust bearing in a bike. If the changes were very notchy as well as the rumble then it would be the clutch plates, the edges of the plates sometimes have burrs on them that cause the clutch to bind slightly during gear changes, these burrs can be removed by hand with a light file, sometimes they stop the plates from seating against each other properly and this can cause clutch slip or rumble.
Yes, I do most of my own maintenance, no, I do not want to do yours. Also the R3 clutch looks like a right pig to get to.
I noticed same thing when I purchased my second hand 2005 R3 from a dealer.
When I complained about it, he started a brand new R3 up and it had the same noice.
It must be "normal" then; at least so far, from the posts that I've seen here.
My VTX1300R has a "change" in sound as well once the clutch lever is released, but nothing like what the Rocket presents. I guess it's just due to the 'hugeness" of the motor?
Ha! That noise drove me nuts when I first bought my '05 rocket second hand. I was sure the thing was going to explode.
After 15,000 miles of my riding it, now with stronger springs and a bit more power too, it still makes the noise, but it hasn't exploded yet.
I wouldn't worry too much about it.
