William A. Hall
Hippybilly
welcome from arizona
not very likely that the angle took out the u joint. however it should be checked with the diff off the ground and also with it compressed. (either loaded or without shock springs.)
more than likely a cap came out and put it into a bind and then broke. when a joint breaks i call it cracking the whip it puts a lot of stress on the other parts.
which joint came loose?
pics?
just info when u loose a front u joint on a car it cracks the whip usually breaking the extension housing and bending the out put shaft sometimes worse like cracking the case. a lot depends on the speed.
either before or after the repair i would check for shaft wobble or leaks from cracks.
hth herman
