Louis
Standard Bore
- Joined
- Jul 9, 2017
- Messages
- 1
- Ride
- Triumph rocket 3 roadster
Having problem with fuel pump 05 rocket The fuel pump works sometimes turn on and then sometimes it won't i wiggled wires around disconnected connectors from the ignition to make sure it wasn't burned wiggled key to see if it was the ignition itself since they're known for that think it might be the ECU i've also replaced all the relays and if the battery is not completely 100% charged the bike will not start any idea ???
