Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
Claviger submitted a new resource:
Generic PC-V Base Map - AFR tables filled in, for use with most bikes and tunes
Read more about this resource...
This is only intended to be a base file to throw in a PC-V if you're using an Autotune module.
Try to use a map in TuneECU that matches your configuration as closely as possible.
You never need to "accept trims" in PC-V if you're using a base map that's close to your motorcycle's modifications. When looking at the trim table, if there are values greater than +/- 20, your TuneECU base tune is not close.
