I have been riding bikes for many years and totally addicted, I bought my Rocket new in 2012 although its plated 2010, that was 70k ago such an awesome bike my others did not get much of a gig although of late they do as big girl is becoming frustrating with the engine idle/ cruse speed / flat spot.
I say all three as no sooner i think i have cured 1 issue the other raises its head.
stepper motor replaced twice, TPS once very early in the piece, cleaning all the sensors, checking all the spade connectors etc.
I would like to hear what is the general consensus on the best tune applicable and tune equipment recommended.
the bike is basically standard just K&N filter, cat by pass and the genuine triumph (sport) mufflers.
In the past I have relied on the shop to tune the variables to suit after I serviced the bike however Its time I did this for myself so any help or suggestions greatly appreciated.
Welcome from Adelaide. Hopefully Hanso can help you with a suitable tune. If that doesn't work ride to Victor Harbor and have Neville Lush dyno-tune it for you. Perhaps wait until the weather warms up a bit!
Hello Mick and welcome from Virginia. You mention the stepper motor twice being replaced. Have you checked the portion of the throttle body where the stepper motor pushes. On my 2014 R3T, the stepper was ruined by miles of road grime which in turned ruined the corresponding pieces of the throttle body unit. That unit is too expensive to replace for me so I purchased a used one and replaced the pieces that were affected. You can try and clean the springs and Teflon/nylon washers, but mine were worn out on the OEM unit. Good luck.
Gday Mate and thanks for the welcome,
your dead right on expensive first unit was replaced by the shop and when I had similar issues not long later I assumed that it was the same issue and purchased another unit and the wallet would prefer not to do that again. I will check this area thanks for the tip.
I had that issue found one of the coil packs was starting to cook. Is gel of some sort was rising out of the socket where you plg in the wire.
