Front end wobble
bobchandler
Standard Bore
I am half way around the country on my 2006 R3 classic. Before I left on this trip I had my triumph dealer change out the front end fork springs to progressives. What I am noticing on this trip is that the front end wobbles a bit especially when making slow speed turns especially from stopped. However, I experimented and found that if I shake the handle bars a little bit when going 25-30 for instance, the front end wobbles as if it wants to keep doing that if you know what I mean? I am afraid to do this at highway speeds. Otherwise the bike seems fine on the road. Any helpful suggestions appreciated.
Bobby C
Mine did that around the 30-35MPH mark. It was fine when slower, and fine when faster. A new front tire helped immensely.
Mine did it severly the other day without warning at 35 mph......scared the piss outa me! I was coasting to a stop, let my hands drop to my sides and it happened :shock:
I have a brand new Avon Cobra @38 psi on front with 1000 miles on it.
I had it happen twice...both times was when i replaced the front tire. NOT BALANCED PROPERLY.
..could also be the steering neck bearings need checked/tightened..as for balancing the tires, I usually try to use dynabeads http://www.innovativebalancing.com/motorcycle.htm ..try to put 'em in the tire before the bead is seated during the tire change if ya have a 90* valve stem..they're a PITA to get in that way..I ended up having a local indy balance my front with a wheel balancer..
