dtgiese
.040 Over
Ok, I took my bike out for a ride and the check engine light came on.
Hooked it up to Tune ECU and it says Lamba sensor problem.
Tried clearing it on Tune ECU but it keeps coming back on.
Now, the Lamba sensor is the same thing as the O2 sensor right?
So I unchecked the O2 sensor and the engine light is still coming on.
Ok I have reverted back to my original tune and unchecked the O2 sensor and the light is now gone.
Dtgiese, when Wayne did your tune was it with the O2 sensor still attached or disconnected and unchecked?
Crap, it was running nice with your tune Dtgiese
But I can not continue riding with check engine light on.
Mac
Hey Mac, it was tuned with the O2 sensor on and I have left it on since with no check engine light. Comparing the tune you were using to mine there are alot of differences not only in the fuel tables but also the Ignition tables. You may consider running the tune for awhile and see if the check engine light will go out after a short time. Your O2 sensor has been seeing a very lean burn and my tune is substantially richer so I don't think it could hurt anything running it for awhile.
Anyway, I finally found the dyno sheet I got from Wayne, it was done early in the tuning process and before we discovered I had an exhaust leak so I know the numbers are a little better but it shows 139.1 BHP and 137.3 Ft/Lbs
Dennis
