Electrical question
grizzdan
.040 Over
Port Orchard
Im finishing up installing my EB fusebox the last thing I need to do is hook the relay to a switched wire. The wire I want to use is a unused plug that can be seen in the manual under the three relays on page 18.26. It is switched power but I don't know what its for would this be a good place to tap into?
track back the rear running light, up the rear fender to the harness, tap, run the wire to near where you set the box
You may be referring to the EVAP canister purge (fitted to Californian bikes). If it's a switched power wire - use it.
