ArekDeBoss
Turbocharged
Lalaland
Rocket 3 GT 2022
I can not locate relay for indicators.
I have located few but they seem way too small. Please see a picture.
I can not find in a manual a location for indicators relay anywhere.
Can somebody help?
It's for sequential LED indicators which even with resistors flash normal frequency but only half way through.
When connected directly to the battery they flash fine. When connected to old indicators plugs they don't. Not at all until added resistors. Then after that only half a way. So I need to locate a relay.
Help please
Forgot to mention it's 2021 GT rocket
Can somebody help?
Help please
There is NO relay in this bike for blinkers.
There is also NO any light switch for brake lights, no where on brake lever or elsewhere.
The BINLKING SIGNAL is sent by instrument/dash.
Brake lights are also controlled by instrument/dash+ ABS module ECU.
So far no person has been able to install sequential indicators, hope you become the first one.
Good luck
Brake lights are also controlled by instrument/dash.
Good luck
Are you being serious? All this digging and disassembling for nothing?
Never give up, how about in line diode like we have to do on touring.
Somethings are meant to give up, CAN BUS in encrypted so even professional companies are unable to add extra rear brake lights to this bike. Same goes for sequential blinkers, even ABS bleed is not possible with tuneeecu and 'dealertookUK' aftermarket software, I bought both and asked them why ABS bleed does not work and they said 'sorry'. I have emails from them.
I am waiting, looking here and there on FB etc, maybe someday someone will figure this canbus stuff.
At least you got to see the guts…Triumph does make a set of scrolling indicators for the bike and I understand they have to be activated in teh software by the dealer before they will work properly. You might just need a software udpate. I had a similar thing on my Zero EV motorcycle when going from regular incandescent bulbs to the LED. The dealer just flipped a bit in the software to account for the resistance change so the computer knew the lights were working as normal.
Will call them to ask
