I just fitted a new Excedra Max rear tire, and tried to get dyna beads through the valve stem with no luck,,,:cry: is there a secret to this??, I have used this method on other bikes with no problem.. TIA
Some have (I have in the past) used a vibrating scriber held against the stem; which helps the beads move around and flow into the stem (core removed, of course) but you knew that.... :wink:
Use anything that will vibrate. Use your imagination ;-)
yep, tried all the tricks that I know, the stem looks like a real 90 degree angle and has a metal bulb on it, must be OEM valve stem, they just won't go in
