boogerdave
Nitrous
I believe since the changed the pressure plate the only fiber that needs to be monitored is the bottom one. It has a larger I.D. so it fits around the anti-judder spring and seat. If you switch to MTC fibers you remover the Anti-Judder spring and seat and all fibers have the same I.D.
why did you have the basket off Dave? Detewnt Spring? How did the back of the basket look? I am talking about the backlash eliminator springs and seats.
Everything looked good on the basket. I thought the clutch may be slipping and making some noise . . didnt find anything except the auxiliary chain was WAY sloppy. I did the upgrades on the lifter and the lifter rod, replaced the chain, detent spring and decided to do the clutch plates and springs while I was in there. I got side tracked converting Nm to Ft lb and didnt do the clutch nut . .
