Ted Biggie
Here is a recent test of the usual suspects with additive and water vs additive and coolant:
Cooling System Additives - Turbo and High-Tech Performance Magazine
The synopsis:
They all work, they all work incredibly well with just water additive and distilled, and acceptably well as additive and coolant.
Distilled will keep your engine cooler and prevent overheating in the first place, antifreeze will tolerate minor overheating better but cannot expel heat as efficiently because precious few materials have the heat capacity of good old water.
This is the bottom line. Water has the best heat transfer - better than PG, ethanol, methanol, etc. Coolant provides corrosion and freeze protection but lowers the overall efficiency of your cooling system. If you're in an environment that isn't prone to freezing, you can use water with a corrosion inhibiting product for more efficient heat transfer. Since your system is closed loop and operates under pressure it's not going to boil unless you have a legitimate system issue like failed water pump or cooling fan. Oh, and Evans is crap.
Here's a good video to watch:
While I like distilled water, I prefer distilled Corn or Rye !!
