Checking cam clearances
valmacmiami
.060 Over
It is time for me to check my camshaft clearances is there a shim kit I can buy or do I have to measure first then order the shims.
Check the valve clearances, odds are they will be within spec. Mine have been fine everytime for over 50,000. If not you have to order the required shim. I asked at my dealer and they said there is no kit, which I though was odd
You've never needed them adjusted since you had the bike?
I know a chap with a 2006 with 65000miles, all he's done in that time is yearly oil changes and one throttle body reset.
