Ya see there's your problem.
And there may be more like it.
Your throttle balance numbers are in the 600s now so you're getting close.
Check all vac tubes and the 4 blanks for integrity and good tight connections.
Then you can balance throttles and do another ISCV reset (because adjusting throttles will change the TPS reading)
Where are the blanks located? Under the plenum cover?
I will say, the large quantity of black smoke has all but stopped. So I'm definitely on the right track
You can read and write but only with the cable. There is a manual perhaps on Tuneecu.net, downloads. I could email it to you.
I was pretty sure the tuneecu website said with the obdlink lx I can rewrite the maps, I hope this is correct.
I can't see anything now, as far as a map is concerned
The green arrows show the 3 nipples that the 3 vacuum tubes connect to.
The yellow arrows show the 3 blanks on each TB.
The blue arrow is the 4th one which is normally blanked too but it is used for emissions compliance crap on California models.
Thank you. Heading out now. Luckily I live so far from Cali
Everything appeared to be in shape. It got dark quick and mosquitos are nasty so I had to call it a night. I'll be at it first thing tomorrow, after I get myself right with God.
Thanks for all the help so far. Bike will be aces before long!
