R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,597
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
If they’re the same at idle (value doesn’t matter) there’s probably no leak.
On the contrary. This is a myth. A stock bike idling should be in the 600s iirc. 900s is getting close to atmospheric pressure. 900s are pressures the MAP sees at wide open throttle I.e. lots of air rushing in. And so the ECU dumps in fuel to match and maintain AFR.
Trouble is when the bike is at or near idle, I.e. little air going in, and the MAP sensor sees 900s, the result is loads of fuel dumped in and causes mad rich condition causing the black smoke and bogging and dying the guy is seeing.
The MAP sensor seeing 900s is probably because the vac tube on it is loose or cracked or one of the rubber blanks on one of the other 4 nipples on the throttle bodies is missing or broken.
Besides the 970hPa MAP values the screenshot also showed the injector pulse time of 13ms which is long afaik so looooads of fuel being dumped in.
But that's the result of the 970hPa MAP value.
What's causing the MAP sensor to see 970hPa is the problem here. Its seeing almost atmospheric pressure.
