Can someone please help with my exhaust question?
Casper Rocket-Man
Standard Bore
Rocket III Classsic 2010 (2009 1st reg'd 2010)
Hi everyone, I own a 2010 rocket iii classic roadster (seems to have mostly 2009 parts though, must have been a crossover).
I have the 3 separate exhausts on my model, the left hand one has rusted off at the U bend right next to the catalytic converter.
My question is, could I remove all 3 exhausts and the catalytic converter, then where the 3 into 1 manifold comes down to a straight tube could I put a single silencer on that such as a universal one (can get them for about £60 but not sure on the size of the down pipe diameter)?
I am on disability so I cannot afford to by a real nice exhaust system and currently on ebay the only left hand pipes available are in the states and they will not post to the UK (I asked) and one in Norway which is in quite bad condition for the price (£165).
Either that or if someone has an exhaust they would be willing to sell me (if its not to expensive) I would be interested.
Any help would be massively appreciated.
its unclear to me where it is rusted at but
can u plug the rusted one and that will forse the exhaust to go out the other two?
It's the LH pipe and it's rusted where it connects to the cat, the inch that goes over the cat is still in the clamp lol but the bit directly behind the clamp is where it's rusted off completely. I either need a replacement lh muffler or delete the lot and put a pipe on the down pipe from the manifold. Tried to find a replacement lh pipe and there are 2 I USA (won't deliver to uk) and one in Norway which looks rough. If I go with a system delete I need to find out the diameter of the down pipe off the manifold. Thanks for replying tho.
Have you tried to remove the pipe along with the portion still on the cat and see if you can get a new piece fabbed up to replace the rusted part. I'm guessing most muffler shops could do this welding things up for you.
Just took it off, think it is weldable.
