Break/running light out
JDuke1980
Turbocharged
Georgia
My break/running light won't work.
I am getting power to the outlet, 12v (+/_)
I tested the bulb w/ a 9v battery, it works.
Neither the break light or running light will work.
Any ideas why it won't light up?
I agree, if your bulb is ok & your getting 12v to the light then the fault must lie in the earth (ground) return. Earth faults can be notoriously difficult to find but should be quite simple in this case, good luck.
Fixed. Don't know how, but it is. Took the fender off, inspected everything. Checked where the trailer lights were wired in, un-taped them. They were fine. Re-taped them. Gave up. Put it back together and it worked. I guess it was where I re-taped it even though it looked fine.... any way, thanks for the help.
