lonsomecrow
.040 Over
Last week when I changed my front brake pads and after riding few miles yesterday I noticed that the fluid level is way too below.
Then today I bought brake fluid and bleeder pipe.
I following the manual page 347-348. And when I reached step 7, which says remove the reservoir cover, I noticed that the first blunder was that the fluid level wasn't low, reservoir was FULL with fluid and may be that was the reason I did not see the level.
Anyway I started with the right caliper first and followed the steps in manual and closed the bleed nipple after that.
Then while the reservoir still open , I started the same procedure for left caliper when I follow through the steps and release the bleed nipple, I could see the bubble coming in the bleed pipe and after that I pull the lever slowly to the handle. Next while it is pulled, I have to see that there is NO AIR in the bleed pipe and when there is no air and no bubbles, I have to fasten the bleed nipple. But the fluid stops flowing in the bleed pipe as soon as I pull the brake level to handle bar. and all that I se in the bleed pipe is air and bubble and flow is stopped. I THINK I SCREWED it completely. Can anyone please help me and explain what is wrong here? My trip is coming this week and I do not want to miss it ....
I keep repeating step 9 and step 10 but bubbles are NOT going away from the bleed pipe.... would appreciate the responses
