Additional front lights
jthree
Turbocharged
Ontario, Canada
2007 Rocket III Classic
I have some lights similar to these and I'm looking for a good spot to mount them. Where have you guys mounted your lights? Pictures would be great.
Well, as luck would have it, I bought a wind-shield from a captain some time ago and it ended up showing up with only one set of mounts, so I had to buy a full set. While I was trying to mount the lights, my son came in and said "it's too bad you don't have a bracket like the one on the wind-shield". Well guess what, I said, it just so happens I do. So after some minor modifications to the brackets and the lights, they are on the bike. I mounted both, side by side, between the forks under the headlights. While I was at it I switched the bulbs for Silverstar Ultras. Between the EB kit and the new bulbs, man what a difference.
I also installed some Hyperlites on the back so hopefully I'll be seen a little better now.
I'll post pictures once the bike is back together.
I used the Triumph spots, that come with brackets.. clip on the screen bracket.
Me too - plus a second identical set with a different name mounted low on the engine bars. Now both converted to LEDs.
[video=youtube;VF9JGnu9B_8]http://www.youtube.com/watch?v=VF9JGnu9B_8[/video]
The higher you mount them (within reason) the better they'll be seen and the better they'll illuminate the road.
I fitted mine on the bottom bolts of the rad........
Will post photos when photobucket is back up
