Tal
- Joined
- Dec 20, 2015
- Messages
- 5,887
- Location
- Christchurch, New Zealand
- Ride
- 2021 Triumph Rocket 3 GT.
The first model of that series, the new Triumph Thruxton TFC debuted as a lighter, more powerful, and more exclusive version of the Thruxton R, and we were duly impressed. Then Hinckley teased us with a hot-rodded working concept of the next bike on deck, the Concept Rocket 3 TFC, a full-tilt bored-and-stroked behemoth that claimed an all-new triple-cylinder engine.
With its beastly 2,500cc inline-triple engine, the Rocket 3 TFC claims to have the world’s “largest production motorcycle engine,” and the most torque of any production motorcycle.
Courtesy Triumph Motorcycles
And now comes that bike in all its official production glory, rolling with a massive new 2,500cc Triumph triple engine, a muscular presence, up-spec technology, a refined design, and an impressive level of premium specification equipment.
The original 2,295cc Rocket III was already a show-stopper when it launched in 2004, and this follow-up improves on the tank-like original’s lines with a cleaner, more elegantly swept demeanor that reshapes the fuel tank, tucks in or ditches much of the bodywork from yore, and sleekens the silhouette for a lighter visual load. The attitude adjustment is subtle though, and the 2019 Rocket 3 TFC still brings some swagger with those 20-spoke cast aluminum wheels and the signature 240mm rear tire.
Still chunky? Yeah, but at least the newest Rocket drops some pounds and reshapes its overall lines for a cleaner, more streamlined look.
But the main attraction has to be that whopping, all-new 2,500cc triple, which once again claims the title of “largest production motorcycle engine in the world.” It also claims to have the highest torque of any production motorcycle, with Triumph indicating a peak number of “more than 163 pound-feet.” It stands to reason that Triumph would piggyback on that claim by also alleging the new Rocket 3 TFC is the most powerful Triumph to date, with 168 hp said to be on tap, or 13 percent higher than the first-gen Rocket III.
The higher-capacity 2019 Rocket TFC powerplant, says Triumph, is central to its “class-leading performance.” Hinckley also boasts that the massive triple delivers a “staggering 70 percent more torque than its closest competitors,” but we’re not exactly sure who that would be. Regardless, the triple engine brings premium components to the table, like state-of-the-art lightweight titanium inlet valves to allow for higher revving, and custom-made Arrow mufflers with high-zoot carbon-fiber end-caps to push out the spent gases.
The Rocket 3 TFC cradles the big triple within an all-new aluminum frame that uses the engine as a stressed member for mass optimization, and also helps bring weight down by a significant 88 pounds so you’ll feel the engine’s added juice even more. The new aluminum single-sided swingarm, lighter engine components, carbon-fiber bodywork, and leaner braking components help the Rocket 3 shed pounds as well.
A new aluminum frame and new single-sided swingarm help lighten the 2019 Rocket 3 TFC to enhance power and handling. Carbon-fiber bits add a premium look.
Less weight enhances power and improves handling, but upspec components help too, and the Rocket 3 TFC has that covered. In the braking department you’ll find premium Brembo Stylema calipers and Brembo Monoblock brakes, radial master cylinder, and MCS span, ratio-adjustable brake lever, and matching clutch lever. It’s all enhanced by optimized cornering ABS and traction control. Handling bounce duties is an adjustable 47mm inverted Showa cartridge fork, and a fully adjustable Showa monoshock out back with piggyback reservoir.
Triumph graces its latest Factory Custom model with Brembo calipers and Monoblocks, supplemented with cornering ABS and traction control.
In the cockpit, controls and displays have been upgraded as well, with the latest full-color TFT instruments adding major boost in functionality; riders can choose from two information layout themes and can personalize their start-up screen. On the screens, you can choose from four riding modes (Road, Rain, Sport, and Rider-Configurable) that act to adjust the throttle map and traction control settings to either suit riding conditions or your own preference. The Rocket 3 TFC also comes with cruise control, Triumph Shift Assist, and Hill Hold Control as standard features; Shift Assist allows for clutchless shifts, while Hill Hold stops the bike from rolling backward on an incline. Added convenience and security features include a keyless ignition, Tire Pressure Monitoring System (TPMS), and a USB charging socket.
RELATED: Triumph Teases New High-Performance Rocket Factory Custom
If you want to ride connected, an accessory Bluetooth module enables the Rocket 3 Triumph Factory Custom’s advanced TFT instruments with full connectivity to a motorcycle-integrated “GoPro” control system (the world’s first, says Triumph), Triumph’s “turn-by-turn” navigation system (powered by Google), as well as music and phone operation. The system looks similar to the recently released Scrambler 1200’s.
Totally updated and upgraded electronics in the cockpit include a new full-color TFT display with four riding modes as well as Hill Hold Control and TPMS.
Back on the visual front, you’ll still see those familiar twin bug-eye headlights, though they’ve been reshaped and are now full-LEDs. Internally wired flat handlebars hover over a flat-ish carbon-fiber fly screen, with other carbon-fiber parts including the front fender, muffler end-caps, exhaust heat shields, drive shaft cover, heel guards, and tank strap. Smaller details are subtle but slick, like the one-of-a-kind, twin carbon black and matte carbon black paint scheme with brushed foil decals, gold accents, and electroformed 3-D Triumph badge all contributing to a minimal rear end.
Then there are the premium details that remind you of the TFC’s pedigree—things like a genuine leather interchangeable dual or solo saddle standard (with an infill pad supplied for the single-seat setup); a single-sided swingarm; sexy, sculpted three-header exhaust; and premium TFC badging with gold detailing. A pretty-sweet-looking numbered plaque on the instrument mount, each one totally unique, seals the deal. Additionally, every Rocket TFC owner gets a tailor-made TFC hand-over pack which includes a letter signed by Triumph’s CEO Nick Bloor, a personalized custom build book, leather rucksack, and a TFC indoor bike cover.
Each Rocket 3 TFC carries a unique, individually numbered plaque.
As we said earlier, only 750 of these beauties will be available worldwide, with 225 units slated for North America. Pricing is set at $29,000 (US). Once the production run is done, it’s done and won’t be repeated, says Triumph. More exclusive TFC models are in the works, so we’ll be keeping a sharp eye out.
