Hey she might only be a 2008 but its the hottest motorcycle ever made 😁😎 spend up now if you hoon solo, top speed stuff, suspension is the best upgrades you will do to the big girl. Race tech emulators ( others available now same price range) up front are not expensive and improve forks alot. If you hoon or go fast, something you can adjust slow speed compression, high speed compression, height. It changes the ride. You can use ohlin 777 for hd readily available everywhere about 750 you will have to change eyelets no problem. Some pictures of an ole 08 ready for pastu
Suspension bottoming out causing spine jarring hits usually means the preload is too little. The shock travel is 4.13 inches. When you and the spouse sit on it does it take up about 3 inches? If so that leaves 1 inch before spinal detonation on a moderate bump. If you jack the preload all the way up to max stiff and you get only 1 extra inch of spring travel you need a new set of shocks. With you and your spouse onboard there should be at least 3.5 inches of shock travel available to absorb hits from the road.
