Those who have Nev's Lockup Clutch...
Zilla
Standard Bore
'05 R3 Classic
Has anyone bought aftermarket clutch plates, or are the factory plates fine?
Is there a gasket or o-ring that needs to be replaced when the front assembly piece is taken off to install Nev's lockup clutch?
Thanks in advance Captains!
Stock plates are fine :wink: as for the gasket or O ring,I carnt remember that far back :oops: sorry
Front cover gasket, o ring's for the water pump inner shaft and outer cover, and o ring for the bypass pipe, the stock linings are fine as JD already stated....... :wink:
Who sells those gaskets and o-rings?
Would have to come from the dealers, you may be able to source the o rings from an outside supplier, but you would need a sample to match up with.
