Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,967
- Location
- Ride
SIZE MATTERS!
Get the biggest screen made by Triumph ever! This is not just the screen it is the Chrome QR and Locking bracket and Complete mounting system as well.
I can see why you want to lock them!
Geez, these are expensive in the UK and that is WITHOUT the complete mounting system !
JUST Part #34 in parts diagram below is £540.00 (AU$, US$ )
I have ALL the bits in the image #1 below EXCEPT the small SUMMER screen #2
Triumph Motorcycles | Parts Catalog | Triumph Parts | Triumph Clothing | Triumph Accessories
QUICK RELEASE ROADSTER WINDSHIELD A9708111
Can be used with Windshield Lock Kit A9938030
and I happen to have just one (1) of them left to go with it!
Ref Part No Description Price (Each) Req Qty Qty/Add To Cart
1 PFKL1210316 SCREEN ASSY SUMMER POLISHED £540.00 €583.20 1
2 PFKL1210298 SCREEN, MOULDING, SUMMER £234.00 €252.72 1
3 PFKL1210309 SCREEN, AIR DEFLECTOR £64.04 €69.16 2
4 PFKL1210291 BRACE,SCREEN,FRONT,CROSS £105.00 €113.40 1
5 PFKL1210292 BRACE,SCREEN,FRONT,LH £33.40 €36.07 1 - unavailable -
6 PFKL1210293 BRACE,SCREEN,FRONT,RH £33.40 €36.07 1 - unavailable -
7 PFKL1210317 BRACE,SCREEN,REAR,POLISHED £28.62 €30.91 1 - unavailable -
8 PFKL1210310 BRACE, SCREEN, DEFLECTOR, LH £17.86 €19.29 1 - unavailable -
9 PFKL1210311 BRACE, SCREEN, DEFLECTOR, RH £17.86 €19.29 1
10 PFKL1210318 BRACKET,SCREEN LH, POLISHED £27.04 €29.20 1 - unavailable -
11 PFKL1210319 BRACKET,SCREEN RH,POLISHED £27.04 €29.20 1 - unavailable -
12 PFKL1210320 BRACKET,LEVER LH,POLISHED £8.58 €9.27 1 - unavailable -
13 PFKL1210321 BRACKET,LEVER RH,POLISHED £8.58 €9.27 1 - unavailable -
14 PFKL1210322 BRACKET,STOP LH,POLISHED £6.23 €6.73 1 - unavailable -
15 PFKL1210323 BRACKET,STOP RH,POLISHED £6.23 €6.73 1 - unavailable -
16 PFKL1210325 BUSH,SHOULDERED,POLISHED £4.06 €4.38 2 - unavailable -
17 PFKL1210307 SPRING,TENSION £3.67 €3.96 2
18 PFKL1215171 WASHER, WAVE SPRING, M10 £2.04 €2.20 2
19 PFKL1210299 GASKET,FRONT,CROSS £29.16 €31.49 1 - unavailable -
20 PFKL1210300 GASKET,FRONT £13.00 €14.04 2 - unavailable -
21 PFKL1210301 GASKET,REAR,CROSS £14.41 €15.56 1 - unavailable -
22 PFKL2313459 BRKT,COCKPIT INFILL,RH £8.34 €9.01 2
23 PFKL1210312 GASKET, DEFLECTOR, FRONT £10.26 €11.08 2 - unavailable -
24 PFKL1210313 GASKET, DEFLECTOR, REAR £10.26 €11.08 2 - unavailable -
25 PFKL1214580 SCREW,M6 X 20 £3.23 €3.49 2 - unavailable -
26 PFKL1214582 SCREW,M6 X 16 £2.84 €3.07 17
27 PFKL1213581 SPACER, OD9.5, ID6.3 £2.33 €2.52 15
28 PFKL1214823 DOMENUT, M6 £1.90 €2.05 15
29 PFKL2019752 WASHER,NYLON,12X6X0.8 £2.26 €2.44 15
30 PFKL1218748 LABEL.WINDSCREEN CLEANING £2.04 €2.20 1
31 PFKL1215743 CLIP, U-SECTION, TRIM £2.11 €2.28 2
32 PFKL1215568 TRIM, U-CHANNEL, 990MM £4.13 €4.46 1
34 PFKL1189837 ROADSTER WINDSHIELD KIT, POL £468.66 €506.15 1 - unavailable -
