Yup - I've just designed my own lighting loom. - so what exactly did you have in mind skip? 3* main/dip? Can probably draw the plans up tomorrow at work.
Sorry for the delay.
Been kind of hectic around here lately.
I bought 3 new headlights.
Each one is W/ 12V 35/35W H6bulbs.
They have 3 wires coming out, white,blue, and green.
i want to install a relay (or two, whatever it takes),
and running it all to a PC8 fuse block, located under the seat.
I don't know if I need a SPST relay, a DPST, or a DPDT, or even more than one.
i don't know if the Triumph wiring harness is big enough to carry the load of 3 headlights without getting hot.
I don't even know if I should run the headlights in parallel sequence, or just run a jumper from the primary on down the line...
i know what I want to do, I just don't know how to get there from here.
oh yea, I want a kill switch (rocker toggle) for the headlights on the left side cover.
To be outside the ignition switch system if possible and/ or necessary.
Guess that about covers that part.
What I want is the shortest, simplest, Best wiring diagram for this application.
My leds are another problem.
if you want to diagram something like this up,
I sure would appreciate it.
Any and all help would Sure be appreciated.
Skip
