oteczdmitriy
35 season
The background.
In the summer of 2023, a drunk old man was intercepted, the consequences are in the picture,
it was a Roadster 2010. Two months later, a 2017 Roadster appeared in the garage.
The frame 2010 was not damaged, and all the engine mounting bolts were removed by hand. In the winter of 2024-2025, the 2010 Roadster was completely restored by me. The engine mounting bolts were also installed without problems. New (without damage) : lower traverse, steering column bearings, fork, front wheel.
Now the question - when measuring the 2017 Rosdster. Rosdster 2010 has the same dimensions: the length of the fork leg to the axis is 81 cm,
the angle of the fork is 59.35 degrees,
DIFFERENT MEASUREMENTS from the axis to the rail mounting bolt are 57 cm for 2017,
54 cm for 2010!!!!
What the hell?
I would appreciate the information provided- the distance from the front rail mounting bolt to the center of the front wheel axle. (as in the picture).
54 cm for 2010!!!!
What the hell?
