Here is the responce I just received ceom McCruise.
Hi Eric,
Disconnect any one of the three pipe B’s from ONE the cylinders and plug the end of the pipe or remove the ‘T’.
Don’t use Pipe C, it won’t have any vacuum. It supplies clean air to the canister to help purge fumes from the canister.
Pipe A is the vent from the tank.
Connect the cruise control vacuum hose to the cylinder you disconnected.
That’s it.
This will still provide plenty of vacuum for the charcoal canister to purge, and ensure good vacuum for the cruise control from one cylinder.
You could just ‘T’ into pipe B but that will not provide anything like as much vacuum to the cruise as just going to one cylinder and could affect the performance of the cruise.
Best Regards,
Frank Guymer
So, now they are saying that I do not need the T. Aweful tight quarters back there. So, by the schematics it appears the rear pipe is what needs to be removed and the pipe plugged with something. And their pipe attached to cylinder 3.
You were correct!
