Big Bald Monkey
Standard Bore
2007 Riii
Hello lovely Triumph people.
I like Triumphs so much that I have 3 of them!
I picked up a 2007 Rocket last November. It seems to have spent most of its life garaged and only has 12500 miles. I am now finally getting around to starting to make it my own which is the main reason for joining the group, to pick up ideas and to find out how things get done.
My first job is to sort out an annoying backfire on deceleration before I delve into some "tasteful" mods.
TunEcu is finally installed on my very old laptop and I am now off out to check throttle bodies sync, tps etc.
Ride safe,
Mark
Greetings from sunny North Texas, Mark. You have a nice start on Triumphs with 3. Your decel pop may be due to after-market pipes with low back pressure. If that's the case you can tune some of that out by adding a bit more fuel on the L tables in TuneECU. There are some guides on how to do that here in the forum, just search on decel pop and you should get some info you can use.
