Hello from Florida
Welcome from Wisconsin! The price is fair for sure.
Things to look for? Leaks, like the cam cover for example. The tires likely look new, but I’d throw a new (and better) set on. Also, the battery is probably gonna need to be replaced soon.
Let us know how she looks!
I'm all about having multiple options when it comes to buying a bike. $6500 is the most I can afford right now and this is one of the few R3s in my area in my price range. Especially since I don't have to worry about dealer fees and what not.
First WELCOME to ya to the mad house!
I think that price is fair as I recently bought a 2011 with 4,000 miles for the same.
Listen to it run - if it sounds good, tight, quiet, and new I'd go for it.
An immediate change of tires is imperative! I use a Bridgestone Exedra Max 240/55R16 on the rear and a Michelin Road 5 150/70R17 rear run reverse on the front.
I see it on Cycle Trader. Good eye, that's probably the best valued one listed.
The seller states "Just went thru a tune up - brand new battery and oil change".
I would get specifics on what he meant by 'tune up'.
Was it just the battery and oil or also the plugs, differential fluid, brake fluid etc. ?
The more he did the less for you to do. Ask for the work order if it was done at a dealer.
Thank you every one for your suggestions; it will make looking at the bike on Sunday much easier. I found @10lbull tire essay and woo-boy was that a rabbit hole to fall into a 1030pm last night; ended up counting tires and not sheep to fall asleep.
Inspection Checklist:
Tires - Dry rot? Flat Spots? Regardless, old rubber will need to be replaced.
Fuel Lines - Ethanol hates machines. R3s are injected, correct? Are there any fuel lines that I should definitely watch out for?
Leaks - Cam covers, oil drain pan. Is the final drive prone to leakage? Or is it grease?
Engine sound - Coming from Harley's, there was always a slight tick on my Street Glide even when brand new. Are the R3 similiar, or should it be a "tickless" sound?
Tune Up - Professional or DIY? Invoice if Professional.
Again, thank you all!
