Warps tricks for assembling clutch.
1 clean pressure plate
ID where the roller bearing goes.
2 clean
ID and
OD of roller bearing.
3 clean
OD of clutch lifter piece where it fits into the ID of the roller bearing.
4 after cleaning I apply a few drops of Loctite Baring adhesive to the OD of The Pressure plate bearing and install. I then amply The same to the OD of the lifter piece and install in the ID of the pressure plate roller bearing.
Let it set up over night.
With these parts secured toget slopp is eliminated which makes is much easier to adjust the proper free play in the system.
I also use external return spring instead of the one on the liftershaft.
The project takes a little longer due to letting the loctite set up over night but I do not have any clutch adjustment problems.
This si not per manual it is just what I do to my bikes.
What really makes the difference is do you know where the centerline of your liftershaft is verses the back of the lifter piece head? I do because I measured it includong the .010" thickness of the clutch cover gasket. This allows me to have the least amount of free play which means I get the most pull and release of the clutch without damaging things.
I also use this clutch lifter piece even though it was made for the newer Rockets
Just my take on it as I am no expert except at breaking stuff
