Paul Bryant
Right from when I first got this bike (February last year with 40K Miles on it) the gear box in this bike has been an absolute pig to change gears, 1st to 2nd is impossible to change fast, if I go slow and methodical I get a clean change, also 4th to 5th graunches almost every gear change I make.I had it down last year to replace 4th and 5th gears along with the 5th gear selector. I looked closely at all the components, nothing seamed to be wrong, damaged or out of place.
Now it's jumping out of 2nd gear which I would say that the engagement dogs are worn as 4th-5th was previously.
This I see as a result of it not changing cleanly. 4th to 5th is still the same as it ever was so I can see that these two are going to wear the dogs again and need replacement sometime in the future.
Now (in my mind) I'm trying visulize all of the gear change components trying to suss what is causing this craunchy selection of gears.
The darn thing feels like a Bulldozer gearbox.
I wondered if the selector drum itself may not have been machined correctly in the first place ???
When I had the Engine apart there was nothing obviously wrong with any of the (gear change) components, hence me wondering about original machining etc.
I checked with Andy Lauritzen at North County Yamaha, below is our correspondence.
Hi Andy, just today I've felt my 2006 Rocket jumping out of second gear, could you give me price and availability of the list below please, along with the shipping out here to New Zealand. The engine number is COOL-56247114.
Clutch cover gasket
Alternator cover gasket
Output cover gasket
Sump cover gasket
Output shaft 2nd gear, No 16 in picture below.
Dog ring, No13 below.
I probably should price the selector fork that locates in the Dog Ring No13 as well.
I've not yet pulled the engine out/down yet, but it's going to have to happen so am getting ready for it.
Thanks,
Paul.
Hey Paul, here’s the breakdown of your parts:
T1260107 clutch cover gasket 8.45
T1260119 alt. cover gasket 9.36
T1260184 output cover gasket 10.68
T1230002 sump cover gasket 13.15
T1180188 2nd gear and dog ring (comes together) 155.77
T1190660 2nd gear selector fork 74.17
Shipping to you is probably around $50.00 but I’ll know better when Shipping is here (it’s Sunday today, bleh)
Let me know what you want and I’ll get it coming!
Andy
Hi Andy, thanks for your quick response, but why were you working on a Sunday ???
I've not pulled the bike down as yet, but will get back to you as soon as I know exactly what I require.
A questions, Guys on the Rocket Forum have spoken about a 2nd gear update kit, is this applicable to my model ? what is included in this kit ?
Also, the gear box in this bike is an absolute pig to change gears, 1st to 2nd is impossible to change fast, I have to go slow and methodical to get a clean change, also 4th to 5th graunches almost every gear change I make.
When I had it down last year to replace 4th and 5th I looked closely at all the components, nothing seamed to be wrong, damaged or out of place. Another question, would a late model, say 2012 Roadster shifter drum fit this model bike (2006) and what would the price of that be?
Thanks for your time.
Regards,
Paul.
Well, we are open 7 days a week, and every great once in a while I have to work Sunday. Not my favorite, but at least it’s a shorter day!
I haven’t found anything specific on a 2nd gear update, but on the earlier RIII (up to engine number 244279) the 2nd output gear and dog ring come together as a kit. On the later engine numbers, those two parts come separately and are different part numbers. The kit is $155.77 and separately the pieces are $147.54.
The shift drum is kinda the same. Up to engine 212561 takes one drum, and engine 212562 and beyond takes another drum. However, I don’t think my USA engine numbers match up with yours! Triumph doesn’t say what is different, and all the surrounding parts are the same, so it appears either drum would fit, but I’m not certain that it would work. The drum for the later engine numbers is $194.47 and the older one is $222.28.
There’s something for you to ponder! Hope that helps.
Cheers,
Andy
So you see my Engine number (56247114) is way upon what Andy has quoted so I feel I'm past the update Bikes.
Basically my question is what the hell is wrong with this gearbox ? :cry:
Also this is interesting "However, I don’t think my USA engine numbers match up with yours!" Any thoughts on this ?
I rode a Mates Thunderbird Storm recently, now I'd guess that the gears within this are probably not too much different in size etc to the Rocket, this gearbox changed sweet as a nut all the way up the gears and back down.
It makes me feel like just start swapping parts out and see what the result may be :sad:
Clutch cover gasket
Output cover gasket
Sump cover gasket
Thanks,
Paul.
Andy
Regards,
Paul.
Cheers,
Andy
