jjd
- Joined
- May 20, 2025
- Messages
- 11
- Ride
- R3
Hi all.
I have another thread regarding this one about the MAP sensor, but I have another question for the collective.
This had the failing fourth gear problem, went away to have it sorted. Came back and all seemed well.... except the gear change was reversed, up for first down for the rest. Owner rejected it. Came back with normal gearchange action, owner happy.
However, I noticed that the linkage had been reversed, a new hole drilled in the gearlever on the other side of the gearlever from the factory position. (If you look at the gearlever, the factory hole for the linkage is to the rear of the gearchange shaft, this has had a new hole drilled at the front of the gearlever from the shaft). Whilst this solves the problem, I am not sure what is happening with the selector mech.... Any thoughts?
