Gregger
I have a problem with a pulse in the front brake lever while braking. You can also feel the bikes speed pulse as you come to a stop at slower speeds. There is no pulse while braking at higher speeds. Problem is strictly with the front brake.
My concern is with the amount of freeplay the rotor should have on the floating buttons. From what I know, the front rotor on our Rockets is made up of 3 sections, the inner piece (bolts to the wheel), floating rotor buttons and the outer friction disc held in place to the inner portion with said floating buttons. Mine are seized. The friction disc can't move on the buttons. I cannot spin the buttons by hand either. I'm guessing the rotor cannot float on the buttons which is causing this condition. Checking Youtube, some guys spin the buttons to free them up using either brake cleaner or some penetrating oil and others say don't do anything. What have you guys done to solve this.... or has it been an issue?
Unfortunately I can't do anything till the temps get higher since the Rocket is sleeping for the winder in the cold, cold, cold, shed. (hate winter when I can't go south).
