atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 4,175
- Location
- Keller, TX
- Ride
- 23 Rocket GT, 20 Bobber Blk, 22 Speed Triple RS
There should be a level when cold, right?
Not necessarily. You can run the bottle empty and you should be fine. The expansion of the coolant is contained by the bottle. If you have a level in it at startup there maybe insufficient volume available to hold all the excess volume from the radiator. There's a siphon tube at the bottom of the bottle to draw the coolant back ino the radiator during cooldown (when a vacuum occurs due to volume displacement).
The specific volume of a fluid is the inverse of it's density. If volume goes up density goes down and vice versa. The change in volume is directly related to a fluids temperature. Increasing the temperature increases the volume. If the system is water solid (like your cooling system) the increased volume shows up as a pressure rise since the coolant can't expand initially. As it expands against the rad cap the cap acts like a relief valve at a set pressure to relieve the excess volume to the tank. There is no check valve in the system (valve to prevent reverse flow) so when the bike cools down and the coolant density increases it causes a negative pressure in the system, drawing the coolant back out of the tank. If some air gets drawn in the air will get expelled the next time the coolant flows into the tank since any air circulating in the system will go to the high point (radiator cap).
To know whether or not you have too much coolant in the bottle when cold, simply start and idle the bike until the fan starts. The coolant will rise in the bottle as the system heats up to 200+ degrees. When the fan is running with the bike idling the temperature should be fairly constant (you can check that with a pyrometer). The engine cannot (theoretically) heat past that point since engine heat output to heat sink (atmosphere) are in equilibriium so the coolant volume (level) in the tank will stabilize. No more heat added, no more expansion. Viola.
