R34ME
.060 Over
- Joined
- Aug 5, 2006
- Messages
- 197
I put 750 miles on the Rocket over the last 3 days, bike went well and is making real good power, so good in fact that in 4th or 5th if you give it a handfull the clutch slips, normally around the 3500-4000 rpm then it gradually bites, if you feed the power on gently its ok. I checked and adjusted the cable so I know its should be good, but it continued to slip slightly after I had re adjusted the outer cable at the clutch pivot and also the lever play, I dont think it will improve now, any captains had this issue previously and if so whats the fix?
8)
