But from the sounds of it, I don't think your vibration has to do with the clutch bearing. Your symptoms sound more like transmission or maybe clutch drum. Either way, you will likely still need to replace the old clutch parts mentioned in the warning thread.
If any of you are in the process of clutch repairs and your replacing the thrust bearing, you can get the bearing and washer from Mcmaster Carr faster and less $$$
5909K13 - Bearing 15mm x 28mm x 2mm
5909K73 - Washer 15mm x 28mm x 1mm
