clonking clutch!!!
RiderRocketman
Twin Cities, MN USA
Your clutch is probably ok. Hard to say what the vibration is from but that clonking would be from your transmission and like the Dr said, improper clutch cable adjustment can make the tranny shift badly.
Find my thread in the how-to area about installing a new clutch cable. There's details on how to adjust the cable there. Generally though I'd loosen the clutch more to help make the tranny smoother. Do this by untightening the large locknut and loosen the adjustment nut (turn counterclockwise) a quarter turn at a time and test.
You may also have the older clutch lifter shaft that does not allow for as much clutch release thus not disengaging the tranny enough. Read more at the Clutch Warning thread here:
With any luck, all you need is a little clutch cable adjustment. If not adjustment help then off to the dealer you have to go. Good luck!
toshbens said:
:D Just to say I adjusted the clutch like you said and the clonk seems to have gone only doing it on 2 occasions on a 100 mile ride, nice one cheers!!!!
2 clonks per 100 mile , sounds good to me :lol:
