Clearing Service Light after disconnecting battery
To reset the service interval with TuneECU:
Ensure you've set the time and date correctly in the bike's display.
Connect TuneECU with the ignition on.
From the "tables" page, swipe left to either the Dashboard or Adjustments page.
From the menu in the upper-right corner (ECU?), select "Tests & Adjustments".
From the "Test Devices" window, select "Adjustments" from the bottom-left corner.
From the "Adjustments" window, select "Reset Service Interval" then select "Run" from the bottom-right corner.
Select Km or Miles, set the desired updated service interval, then select "Validate" from the bottom-right corner.
There might be a step or two after that, but I didn't want to reset mine in the process.
If you don't have TuneECU then get a Triumph OBDStar scan tool, it does (mostly) what the dealer tool does. Yeah I've got one & it resets that service light and a heap of other stuff.
