Brakeaway
The problem seems to be if it fits a r3 none tourer seems that the grips are differant or the controls not sure which if it's just the grips I was going to put some kuriyakin ISO grips on as these seem to be ok
I have these kuriyakin grips and with a few modifications I got the kaoko to fit .you need to get a longer bolt to attach kaoko to the handle bars plus a bush that will slide along the bolt .you will then need to grind the bush down to the corret length to get kaoko to fit and allow you to operate it..I did it and it worked fine. I have a 2008 standard
Ok update on the brakeaway it's not going to fit after further investigation discovered that my brake reservoir is attached to my switch gear so you can't split it to put the support ring in between
Ahhhh sorry bro...... That blows.
I won't tell you how nice the brakeaway is
Looks like the handle on my Roadster. I wish I was home to look, I don't remember exactly how it mounts.
Welcome to the madhouse, with a name like Mayhem you should fit in well. I think that all the res./switchgear is the same, I think you only have to separate the switch bank & the grip. I think it will fit, at least I hope so as I want to fit one on my 09 classic. The cost of shipping is expensive & on top of that is import duty, I am hoping to find some kind hearted captain in US that will send one over as a gift. Accepting of course payment is made in advance.
