How many miles are you guys getting out of your front/rear brake pads?
I've got 19,500 miles on my bike and haven't changed them yet, and haven't noticed any problems whatsoever. I use my rear brake only when stopping from higher speeds. I also feel I'm easy on my brakes.
I'm starting to squeal a little during hard stops in the front only but the thickness still looks fine. Most of my miles are stop and go so i use the brakes a lot but not near as abusive as someone who drives the twisties on the weekend so that's probably why I'm getting good life out of them.
Pads are cheap and easy to replace so I wouldn't push it too much, check the manual for the specs and if they are out, change them. I think it took me 10-15 minutes to change front and rears last time.
Thing I'll be checking next is my discs which I think are now out of spec. Those are expensive...
During the rear tire change inspected the rear pads and they are almost gone, only 8k miles on them. I have had the bike for 2K miles and try to use both brakes and gears when stopping. Hard to tell how the PO operated.
